22 years agoJPEG on NIOS II
Does anyone know how to display JPEGs on the Lancelot VGA daughter card on a NIOS II system? Is there a freely available jpeg component? Could one use the Linux jpeg libraries? Any ideas? I wa...
22 years agoHi janhendrik,
Here is an sample result of JPEG decoding on Nios II. No Hardware Acceleration. I have only Stratix Edition, so -mno-hw-mul option is used to near to Cyclone. -- Hardware -- Nios Dev Board : Stratix edition SOPC config : based on standard32 Nios II /f , ic 4k, dc 8k, hw-div enabled VGA controller added(original) Frecuency : SOPC core : 90MHz VGA dot frec : 40MHz VGA config : 800x600x16 -- Software -- OS : none (HAL) JPEG Decoder : modified "JPEGLS" library. I got from Japanese WEB site. (You may find "jpegls mona" on Google if you read Japanese...). This library uses Divide operation.# I tryed to use IJG source code before. Compiling was passed but it did not work correctly. I give up. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif JPEG Image file : "Sunset.jpeg (800x600)". WindowsXP may include this sample image. JPEG Image is put to ROZIPFS, so this file access might be overhead. -- Result -- Compile Options : Clocks : Time@90MHz (1) -O2 -mno-hw-mul : 3,198M : 35[s] (2) -O2 : 1,280M : 14[s] (3) -O2 -mhw-div : 327M : 3.6[s] I think the result of Cyclone may slower than (1). Because Nios II on Cyclone can not have Barrel Shifter. I'm not sure -mno-hw-mul disable Barrel Shift or not. I hope the info helps. p.s. for More faster JPEG decoding, I think I need to do ... - eliminate divide operation - SIMD custom instruction - Hardware DCT/IDCT - Hardware color conversion (YUV-RGB)
