19 years agoJPEG libraries
Hello All,
I am currently working on a project where I have to read image files (JPEG) from a USB and displaying them on the screen. I installed uClinux and I was wondering if you could give me an advice on what libraries to use for the JPEG decoding. Also, could we display the pics using an X window or not? Thanks. Bouyaka7 Replies
Please check the wiki
http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/framebuffer) If you use the DE2 board, you can read the USB disk as mass storage device, and display the JPEG file with nxview on nanoX window. - Altera_Forum
--- Quote Start --- originally posted by hippo@Mar 29 2007, 08:25 PM please check the wikihttp://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/framebuffer)
if you use the de2 board, you can read the usb disk as mass storage device, and display the jpeg file with nxview on nanox window.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22641)
--- quote end ---
--- Quote End --- Thanks for the prompt answer!! Do you have any good links with information on nxview ? Thanks. Bouyaka.
--- Quote Start --- originally posted by bouyaka+mar 30 2007, 04:50 pm--><div class='quotetop'>quote (bouyaka @ mar 30 2007, 04:50 pm)</div>--- quote start ---
<!--quotebegin-hippo@Mar 29 2007, 08:25 PM please check the wiki
--- quote end ---
--- Quote End --- Thanks for the prompt answer!! Do you have any good links with information on nxview ? Thanks. Bouyaka. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22685)</div> [/b] --- Quote End --- I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/framebuffer) but I ran into this error when trying to run make in the uClinux-dist/ arch/nios2nommu/drivers/altfb.c: In function `altfb_probe': arch/nios2nommu/drivers/altfb.c:161: error: `na_vga_controller_0' undeclared (first use in this function) arch/nios2nommu/drivers/altfb.c:161: error: (Each undeclared identifier is reported only once arch/nios2nommu/drivers/altfb.c:161: error: for each function it appears in.) make[2]: *** [arch/nios2nommu/drivers/altfb.o] Error 1 make[1]: *** [arch/nios2nommu/drivers] Error 2
--- Quote Start --- originally posted by bouyaka@Mar 29 2007, 04:59 PM hello all,i am currently working on a project where i have to read image files (jpeg) from a usb and displaying them on the screen. i installed uclinux and i was wondering if you could give me an advice on what libraries to use for the jpeg decoding. also, could we display the pics using an x window or not?
thanks.
bouyaka
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22636)
--- quote end ---
--- Quote End --- Hi, Bouyaka I will use USB Camera to read image(JPEG) on DE2 board. Can you tall me ,what kind usb camera is your used? It's need porting usb driver? Can you teach me? thanks NiosQ
--- Quote Start --- originally posted by niosq+apr 2 2007, 03:07 am--><div class='quotetop'>quote (niosq @ apr 2 2007, 03:07 am)</div>--- quote start ---
<!--quotebegin-bouyaka@Mar 29 2007, 04:59 PM hello all,
thanks.
bouyaka
--- quote end ---
--- Quote End --- Hi, Bouyaka I will use USB Camera to read image(JPEG) on DE2 board. Can you tall me ,what kind usb camera is your used? It's need porting usb driver? Can you teach me? thanks NiosQ <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22728)</div> [/b] --- Quote End --- I am using a normal USB storage device (flash drive) where JPEG pictures will be stored.
nxview is a demo program of nanoX.
when you enable jpeg support in microwin/nanoX, the libjpeg will be selected. I updated the wiki. - Altera_Forum
--- Quote Start --- Hello All, I am currently working on a project where I have to read image files (JPEG) from a USB and displaying them on the screen. I installed uClinux and I was wondering if you could give me an advice on what libraries to use for the JPEG decoding. Also, could we display the pics using an X window or not? Thanks. Bouyaka --- Quote End --- Hi,Bouyaka, are you succesfull display the JPEG picture using nxview to VGA monitor?? Currently I also work a project same with you, if u succesfull make it can share experience to me? Thanks very much for reply =)
