15 years agoJFS corrupt data recovery after power loss
In preparation for a Custom board I'm using the Cyclone II Eval board with the Compact Flash to record data. I need a quick boot - which I've accomplished. (5-8 seconds) The next step wa...
15 years agoIf you want to be sure that the slow speed is due to the PIO0 interface, you could hack the driver and add some read/write access counters. Then from your application, read those counters every second. You can therefore measure the read/write transfer speeds. If you are close to the PIO0 theoretical limit, it means that it is the PIO0 interface that limits your speed, and using a higher PIO or DMA should improve it.
There is an IDE controller on Opencores that you could use but I don't know how well it is tested. We use the Evatronix controller in our projects and it works very well, in all PIO and DMA modes. @Michael: we talked about the industrial compact flash that could recover from a power loss in this thread (http://www.alteraforum.com/forum/showthread.php?t=25702)
