16 years agoJFFS2 kernel support
Hello all I'm trying to add jffs2 support to a kernel (3c120 dev board) and I'm facing an strange problem. If I checked in jffs2 support in menuconfig, _after_ compiling the kernel core and ...
13 years ago --- Quote Start --- If both CPUs try to start Linux, things are going very wrong. This can't work as the NIOS Linux is not SMP enabled and will not be in forseeable future, as the NIOS CPU lacks many features necessary for SMP support. There might be some threads on multiple CPUs here, you might want to read them. And for questions you should start a thread with an appropriate subject line. -Michael --- Quote End --- hi thank you my system with 2 cpus is running very well one running uclinux and another c thanks
