16 years agoJFFS2 kernel support
Hello all I'm trying to add jffs2 support to a kernel (3c120 dev board) and I'm facing an strange problem. If I checked in jffs2 support in menuconfig, _after_ compiling the kernel core and ...
15 years ago --- Quote Start --- Hello Michael !!! thank for you assistence... an374 is a Altera Video Over IP Reference Design, i port to cycloneiii dev board, but i need a webserver and snmp ....so I decided to put another cpu with uclinux...very good....thank you again if someone needs help I'll be glad to help...... cheers Franz Wagner --- Quote End --- Hi Franz, I am looking into porting the an374 to the The NEEK, Cyclone III Edition (consists of the Cyclone III Starter Kit and an LCD/VGA high-speed mezzanine card (HSMC).) It sounds like you were successful in porting the design to one of the Cyclone III boards, was it the same Starter Kit I am looking at? Also, can you tell me what version of Quartus II you were using? Thank you, Tracee
