21 years agoJFFS2 istead of ROMFS
Hi, Please explain to me what is exactly JFFS2 ? Where can I get it ? How can I compile that filesystem to use on uClinux ? And how can I use it instead of the romfs which can be built using...
21 years agoHi Scott,
Your notes remind me that we did run into that problem related with the toggling bit, which does not work because of the way Avalon bus works. We modified that driver to use the polling bit instead, for Nios systems. The modification is included in the last release. Thanks and Regards, wentao
