21 years agoJFFS2 istead of ROMFS
Hi, Please explain to me what is exactly JFFS2 ? Where can I get it ? How can I compile that filesystem to use on uClinux ? And how can I use it instead of the romfs which can be built using...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- BTW: If you're using the AMDLV065D, you'll probably have to deal with the "erase" bug in the CFI chip driver ... I haven't had time to look at the code yet ... so I got lazy & just used cramfs instead ;-)[/b] --- Quote End --- Can you tell more about this bug? Thanks,
