21 years agoJFFS2 istead of ROMFS
Hi, Please explain to me what is exactly JFFS2 ? Where can I get it ? How can I compile that filesystem to use on uClinux ? And how can I use it instead of the romfs which can be built using...
21 years agoHi Dmitry,
> Please explain to me what is exactly JFFS2 ? Journaling Flash File System II. Here's a very good starting point: http://www.enseirb.fr/~kadionik/embedded/u.../howto_mtd.html (http://www.enseirb.fr/~kadionik/embedded/uclinux/mtd/howto_mtd.html) > Where can I get it ? It's already in the Microtronix distribution. > How can I compile that filesystem to use on uClinux ? Enable JFFS2 when configuring the kernel. You'll need an appropriate mtd mapping driver and chip driver. If you're using CFI flash, you can use the one (or both) of the CFI chip drivers already in the source tree. > And how can I use it instead of the romfs which can be built using the > Linux Filesystem Project from NIOS II IDE ? This is a bit more involved & it's much easier if you have a linux development platform (e.g. RH9). Basically, you create a directory tree on your development system that contains all of the inodes (regular, special, etc) that you want for your Nios system, then use the mkfs.jffs2 utility to create a binary image that you program into your flash. BTW: If you're using the AMDLV065D, you'll probably have to deal with the "erase" bug in the CFI chip driver ... I haven't had time to look at the code yet ... so I got lazy & just used cramfs instead ;-) Regards, --Scott
