19 years agojffs2 filesystem not correct
hi we use nios2 on 2C35. it okay with kernel altera (cygwin) or linux with buildroot for kernel 2.6.11 but when i change kernelt for kernel2.6.17 for a test, kernel boot but i got this ...
19 years agobut when i change kernelt for kernel2.6.17 for a test, kernel boot but i got this
jffs2_scan_eraseblock() .... Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes empty_blocks 26, bad_blocks 0, c->nr_blocks 32 jffs2 as some trouble what happen 's ? is this kernel 2.6.17 ok with jffs2 ? futhermore, i try to use TMD utils i get each time erase or eraseall /dev/mtd0: MTD Erase failure: Input/output error hwat is wrong ? is this possible reason: If you get this message for each block than probably write protection is on. Check the WP pin Bests regards <div align='right'><{post_snapback}> (index.php?act=findpost&pid=21712)</div> --- Quote End ---
