21 years agojffs2 filesystem image
Can someone tell me how to create and use a jffs2 filesystem image ? I have correctly partitionned my flash, and I can mount it (in /home for now). I would like to use it for things like /etc, but for this I need to create an image of my system. I have downloaded mkfs.jffs2 from www.psyent.com (as read in another thread) and I have generated an image from a directory (mkfs.jffs2 -pad=0x1A00000 -d etc -o jffs2.img). I am using an AMD S29GL256M flash with 64K erase blocks size, and the size of the partition I want to mount is 0x1A00000. But now, what can I do with the jffs2.img ? I have read that I should copy it somewhere before mounting it (dd if=jffs2.img of=/dev/mtdblock1), but it doesn't seem to work, i.e. there is nothing in the filesystem, and it is not writeable. Anyway it seems normal since /dev/mtdblock1 is on a romfs, so I cannot copy anything on it with dd ! I am obviously missing something here... Can somebody help me ? Thanks Regards pod11 Replies
--- Quote Start --- originally posted by smcnutt@Jun 30 2005, 03:47 PM i'm very fond of cramfs ... it works quite well, generally yields bettercompression than jffs2, and the images are easier to work with. --- Quote End --- I heard good things about squashfs, but the main reasons I haven't tried it out yet are time (duh) and because I do not want to patch the kernel at every release (it's not yet in the main tree).
