21 years agojava with uClinux and Cyclone (Nios2)
Hi, My question is the follow: "There is a way to make a java virtual machine (ex. sun kvm) in uClinux?" if the answer is YES, how? Tnx a lot, Andrea
21 years ago --- Quote Start --- originally posted by overlord80linux@Dec 1 2004, 03:17 AM my processor's number is different from the number specified in the jop's readme, (i've a cyclone ep1c20 series), but perhaps i succeed to adapt it! --- Quote End --- That's a non issue. JOP has been implemented in an ACEX FPGA, Cyclone 1C6 and 1C12, Spartan-II and Spartan-3. There is no difference between EP1C20 and EP1C6 or EP1C12. The main differences are internal memories between ACEX, Cyclone and the Xilinx devices. The second difference depends on the board you are using and the external memory interface. JOP has been used so far with 8-bit, 16-bit and 32-bit SRAM and 32-bit SDRAM. Martin
