21 years agojava with uClinux and Cyclone (Nios2)
Hi, My question is the follow: "There is a way to make a java virtual machine (ex. sun kvm) in uClinux?" if the answer is YES, how? Tnx a lot, Andrea
21 years agoMake a new hardware design with the a new NIOSII and look all ncry peripherals are there. Then compile the software, ... It should work... but I didn't do it (maybe in a next life I can try).
Also I think the Nios emulation of JAVA Bytecodes is a lot slower then the JOP processor doing the instructions directly. But if you can define enough instruction cache, so the entire emulation routine fits in, it can be rather fast I believe.
