13 years agoIssue in setting up Nios 2 C/C++ Application on eclipse
hey, I installed the nios 2 software pack on my windows vista. When i try to create a project, it does not give me the option of "nios 2 c/c++ application on eclipse". Instead, i can create a simp...
13 years agosounds like you are using the older Nios II IDE flow, which uses .ptf and an older Eclipse tool set
the newer flow uses Nios II Software Built Tools (SBT), which uses .sopcinfo if you've generated the SOPC or Qsys system in any recent tool, you should have a .sopcinfo file
