16 years ago
Issue in component editor
Hi all.
I try to write a validation callback for a component I just wrote.
I get a weird TCL issue (that I don't get in a classical TCL script, I checked)
Here is my code:
--- Quote Start ---
set_module_property NAME pio
set_module_property VALIDATION_CALLBACK validate
add_parameter PORT_31_TRISTATE BOOLEAN false
set_parameter_property PORT_31_TRISTATE DEFAULT_VALUE false
set_parameter_property PORT_31_TRISTATE DISPLAY_NAME PORT_31_TRISTATE
set_parameter_property PORT_31_TRISTATE UNITS None
set_parameter_property PORT_31_TRISTATE DISPLAY_HINT ""
set_parameter_property PORT_31_TRISTATE AFFECTS_GENERATION false
set_parameter_property PORT_31_TRISTATE HDL_PARAMETER true
add_parameter PORT_31_INIT STRING TIE_DOWN
set_parameter_property PORT_31_INIT DEFAULT_VALUE TIE_DOWN
set_parameter_property PORT_31_INIT DISPLAY_NAME PORT_31_INIT
set_parameter_property PORT_31_INIT UNITS None
set_parameter_property PORT_31_INIT ALLOWED_RANGES {"TIE_UP" "TIE_DOWN" "HIGH_Z" "INPUT" "INPUT_n"}
set_parameter_property PORT_31_INIT DISPLAY_HINT radio
set_parameter_property PORT_31_INIT AFFECTS_GENERATION false
set_parameter_property PORT_31_INIT HDL_PARAMETER true
proc validate {} {
if {(![get_parameter_value PORT_31_TRISTATE]) && ([get_parameter_value PORT_31_INIT] == "HIGH_Z")} {
send_message error "PORT_31_INIT cannot be set to 'HIGH_Z' as PORT_31_TRISTATE has been set to false"
}[/INDENT]
--- Quote End ---
Then I get the following error message at SOPC Builder startup, when the code is sourced:
--- Quote Start ---
Error: pio_0: can't use non-numeric string as operand of "!"
("if" test expression)
invoked from within
"if {(![get_parameter_value PORT_31_TRISTATE]) && ([get_parameter_value PORT_31_INIT] == "HIGH_Z")} {
send_message error "PORT_31_INIT cannot be set ..."
(procedure "validate" line 2)
invoked from within
"validate"
--- Quote End ---
Can you tell me what is wrong???
Thx
    What is the issue you are seeing?
    Moving to the general nios forum section.
    Oooops I totally forgot to quote the error message.
    I just edited my original post...
    So it seems to be a TCL syntax error but I can't get it...
    Thanks for the reply.
    Unfortunatly, there are no boolean parameters in the _hw.tcl you provided.
    Maybe you can find another one with actual boolean parameters?
    Thx a lot.
    Julien
    If you search through the ip folder for .tcl files you might find one that uses HDL boolean parameters. I was lazy and just used a regular integer parameter in the HDL and then made it appear as a boolean (checkbox) in the GUI by setting the display hint to boolean. By using a display hint of boolean it can only get set to 0 or 1 so you might be able to do the same.
    I'll do that if I really can solve this issue, but it ****es me off as it's only tcl syntax! :D
    I looked in the IP folder and could not find any boolean parameter in any _hw.tcl file...
    problem solved
    --- Quote Start ---
    proc validate {} {
    if {([get_parameter_value PORT_31_TRISTATE] == "false") && ([get_parameter_value PORT_31_INIT] == "HIGH_Z")} {
    }[/INDENT]
    --- Quote End ---
    I had tried that before but I forgot the double quotes around 'false'...
