12 years agoIssue executing sample applications(HPS) provided in the Cyclone V SOC kit related
I have been trying to download the examples provided in the Embedded design suite into the HPS compoment of the Cyclone V Soc. Currently i have ARM DS-5 eclipse through which i am trying to execute the hello world example but there is an error i am encountering in the 'debugging perspective'. The error is as following "Stopping running target Altera - Cyclone V SoC on TCP:localhost on connectionConnected to running target Altera - Cyclone V SoC on TCP:localhost Execution stopped at: S:0x8001BF08 S:0x8001BF08 MOV pc,lr source /v "C:\Program Files (x86)\DS-5\sw\debugger\configdb\Boards\Altera\Cyclone V SoC\..\..\..\Scripts\altera_target_check.py" No SYSID registers could be found. Has a peripheral description file been supplied? source /v "D:\FPGAsofts\hello_7_2\Altera-SoCFPGA-HelloWorld-Baremetal-GNU\semihost_setup.ds" +stop WARNING(CMD315): Target is not running +file $sdir/hello.axf +set semihosting enabled false +set semihosting stack-base __cs3_stack +set semihosting stack-limit __cs3_heap_start +set semihosting heap-base __cs3_heap_start +set semihosting heap-limit __cs3_heap_end +set semihosting enabled true Semihosting server socket created at port 8000 loadfile "D:\FPGAsofts\hello_7_2\Altera-SoCFPGA-HelloWorld-Baremetal-GNU\hello.axf" Target Message: Memory access caused precise abort. Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF1000 ERROR(CMD16-TAD216-NAL18): ! Failed to load "hello.axf" ! Failed to write 16,048 bytes to address S:0xFFFF0000 while writing block of 4,096 bytes to address S:0xFFFF1000 ! Bus error on memory operation. cd "C:\Users\Gowtham\Documents\DS-5 Workspace\Hello_2_7" Working directory "C:\Users\Gowtham\Documents\DS-5 Workspace\Hello_2_7" Please suggest on debugging this issue Thanks in advance, CG6991No RepliesBe the first to reply
