ISR driven UART is missing characters (even at 9600bps... same prob at 230400)
Any ideas on what I'm missing here that is causing me to miss characters?
I'm interfacing to a device that shoots out RS232 packets (up to 200 per second if the bps can handle itI can select the BPS, but it is always N-8-1). Right now, I have the device running (and the UART) at 9600bps and locked to 5 packets per second... although, this problem happens at 115200, 230400, and is terrible at 460800bps(which is where I need to get). The UART seems to be missing characters, especially towards the end of the 'packets' which are around 100bytes in length. towards the front of the packet I seem to get everything and towards the 'rear' it starts to miss them... the 'ISR' itself generally takes 500ns to execute, but that doesn't include the call latency... but I can't see that being a problem at 9600bps... Also the ring-buffer is 4k in size. I have set a breakpoint so that I can debug after it gets 1024 characters and the ring-buffer is missing them... so it can't be a wrapping/overflow problem.... grrrr. Here's how I'm setting up my code in main to test this problem: alt_irq_init (ALT_IRQ_BASE); alt_sys_init(); unsigned char ch; unsigned int baudrate=9600; UsartInit(baudrate); UsartInit_2(baudrate); //register the ISR handler for UART 0) alt_ic_isr_register(UART0_IRQ_INTERRUPT_CONTROLLER_ID, UART0_IRQ, IsrUsart,0,0); //register the ISR handler for UART 1 alt_ic_isr_register(UART1_IRQ_INTERRUPT_CONTROLLER_ID, UART1_IRQ, IsrUsart_2,0,0); //enable Interrupts for UART 0 alt_ic_irq_enable(UART0_IRQ_INTERRUPT_CONTROLLER_ID, UART0_IRQ); //enable Interrupts for UART 1 alt_ic_irq_enable(UART1_IRQ_INTERRUPT_CONTROLLER_ID, UART1_IRQ); There there's the big 'while(1)'in main(): while (1) { //update heartbeat on JP5 header jp5tracker ^= 0x01;//D0 on L.A. IOWR_ALTERA_AVALON_PIO_DATA(JP5_BASE, jp5tracker); while(!UsartIsEmpty_2()) { //toggle LEDG1 when characters are processed from VN100 plugged into the HSMC-ICB greenLEDtracker ^= 0x02; IOWR_ALTERA_AVALON_PIO_DATA ( GLED_BASE , greenLEDtracker ); ch=GetUsart_2(); jp5tracker ^= 0x02;//D1 on L.A. IOWR_ALTERA_AVALON_PIO_DATA(JP5_BASE, jp5tracker); i++;//counter to set a breakpoint with } here's the ISR handler and some helpers for the ring buffer. void UsartInit_2(unsigned int BaudRate_2) { unsigned int divisor_2; divisor_2 = (ALT_CPU_FREQ/BaudRate_2)+1; IOWR_ALTERA_AVALON_UART_DIVISOR(UART1_BASE, divisor_2); IOWR_ALTERA_AVALON_UART_CONTROL(UART1_BASE, ALTERA_AVALON_UART_CONTROL_RRDY_MSK); } void IsrUsart_2(void* context_2, unsigned int id_2) { IOWR_ALTERA_AVALON_PIO_DATA(JP5_BASE, 0xFF);//inserted to time/track this routine //grab data byte and save it USART_RX_buffer_2[USART_RX_hd_2++] = IORD_ALTERA_AVALON_UART_RXDATA(UART1_BASE); //move/wrap buffer pointer if (USART_RX_buffer_2 == '*') z_2==1; if (USART_RX_hd_2 == USART_BUFFER_SIZE_2) USART_RX_hd_2 = 0; USART_RX_full_2 = (USART_RX_hd_2==USART_RX_tl_2); IOWR_ALTERA_AVALON_PIO_DATA(JP5_BASE, 0x00);//inserted to time/track this routine } unsigned char UsartIsEmpty_2() { return ((!USART_RX_full_2) && (USART_RX_hd_2==USART_RX_tl_2)); } //this grabs a single character from the RX circular buffer. unsigned char GetUsart_2(void) { unsigned char rxChar_2; //should never call this w/o checkign status, but it may happen. this keeps //the ring buffer sane during that sort of abuse. if (((!USART_RX_full_2) && (USART_RX_hd_2==USART_RX_tl_2))) return 0x00; else { rxChar_2=USART_RX_buffer_2[USART_RX_tl_2++]; if (USART_RX_tl_2 == (USART_BUFFER_SIZE_2)) USART_RX_tl_2=0; USART_RX_full_2=0; return rxChar_2; } } Anyway... if I write some debug code on a PC to send data... as long as I insert some 'sleeps' in it between characters... never misses a character... Also, I can watch the ISR's debug 'flip' of JP5 and the ISR does get called, and the circular buffer does get populated... it is just missing characters. I have verified (with a PC's serial port) that the packets are being sent properly and contain all the data. Here's what I'm using: DE2-115 development board(cyclone IV) with HSMC-ICB (Altera's INK) Quartus13.0 SP1 with EDS, the UART is: UART (RS-232 Serial Port) Name altera_avalon_uart Version 13.0.1.99.2 Some BSP settings: enable_small_c_library-'checked'.... 'nocheck' for enable_gprof, enable_reduced_device_drivers, or enable_sim_optimize 'none' for sys_clk_timer, and timestamp_timer13 Replies
I'm just starting with these tools, but that does make sense... it is behaving like a stall/flush. I was trying to get the baseline running before I started optimizations to add more features.
I'm wondering if I need to swap the processor to a Nios II/S and lower the amout of instruction cache... refilling that would slow ISR performance too, but the II/F runs really fast in a straight line... It takes about 30 minutes to Generate/Recompile and then I can run my timing tests, so I need to implement some other things and then I can come back to this one and optimize it. - Altera_Forum
Hi David,
i dont understand your problem, but your code for uart was the first, which works me. Thank you. (i have had problem in Quartus 12, NIOS2 EDS 12 that the# include <sys/alt_irq.h> didnt know these commands alt_irq_register(UART1_IRQ,&context_uart1,IsrUart1 ); // install UART1 ISR alt_irq_enable (UART1_IRQ); When i use your init_uart and handle routine, it works: // obsluha preruseni od uartu1 void IsrUart1(void* context, unsigned long id) { int ch; ch = IORD_ALTERA_AVALON_UART_STATUS(UART_1_BASE); // printf("Jsem v preruseni=%X\n",ch); // pokud prisel znak, precti jej if (ch & ALTERA_AVALON_UART_STATUS_RRDY_MSK) { ch = IORD_ALTERA_AVALON_UART_RXDATA(UART_1_BASE); // printf("Ctu znak=%X\n",ch); IOWR_ALTERA_AVALON_UART_STATUS(UART_1_BASE, 0); if (ch==GPS_PREFIX) rx_start=1; if (rx_start==1) { rx_buf[rx_cnt]= ch; if (rx_cnt<RX_BUF) rx_cnt++; if (rx_cnt==RX_BUF) { rx_flag=1; rx_start=0; } } } } // inicializace preruseni od uartu1 void init_uart1() { alt_irq_init (ALT_IRQ_BASE); // alt_sys_init(); // // nastav 9600Bd pro NIOS2 na 80MHz IOWR_ALTERA_AVALON_UART_DIVISOR(UART_1_BASE, 8334); IOWR_ALTERA_AVALON_UART_CONTROL(UART_1_BASE, ALTERA_AVALON_UART_CONTROL_RRDY_MSK); alt_ic_isr_register(UART_1_IRQ_INTERRUPT_CONTROLLER_ID,UART_1_IRQ,IsrUart1,0,0); // povol preruseni od uartu1 alt_ic_irq_enable(UART_1_IRQ_INTERRUPT_CONTROLLER_ID,UART_1_IRQ); } Thanks. Jan, Czech Republic - Altera_Forum
Glad it could help you. And just like dsl said.... My problem was all in how the ISR was handled, the code was fine--I had effectively shot myself in the foot with the NIOSII configuraiton (lots of cache/etc..) That's what makes problems like I had so complicated to fix... there was nothing wrong with the 'C'... it was in how I had configured the NIOSII and the UART... enlarging the buffer and leaving the CPU alone, I was able to run all the way up to 250Kbps (which is the limit of the DE2-115 level converter--e.g. as fast as my hardware could support.. the FPGA/NIOSII/UART could have gone faster.)
