20 years agoISP1761 USB driver
There's a good news. Philips semi had opened their ISP1761 driver on sf.net as GPL. It does support ISO transfer. ( the current ISP1362 driver does not support ISO transfer) It is for 2.6.9 ...
20 years agoHi,hippo
Do you know the possible reasons of the following phenomenon: (a uclinux system had trasplanted into the board DE2 successful,and the usb camera can work) I was programming for grabbling picture via video4liux API which was used for USB camer. I can obtain the camera and the picture information using ioctl() function: fd=open("dev/v4l/video0",O_RDWR); ........... int cap=ioctl(fd,VIDIOCGCAP,& capability); .......... int pic=ioctl(fd,VIDIOCGPICT,& picture); return value: fd=3; cap=0; pic=0; Above code could work ,and the correct information was obtained. but when used the following code ,a problem was generated struct video_mbuf mbuf; ........... struct video_mmap grab_buf; grab_buf.frame=0; grab_buf.height=240; grab_buf.width=320; grab_buf.format=VIDEO_PALETTE_RGB24; char *data; data=mmap(0,mbuf.size,PROT_READ|PROT_WRITE,MAP_SHARED,fd,0); .................. int grab=ioctl(fd,VIDIOCMCAPTURE,&grab_buf); ................. int sync=ioctl(fd,VIDIOCSYNC,& grab_buf.frame); ............. the return value: data=-1 grab=-1; sync=-1 That's to say ,the process of grabbing a frame_picture work failed! do you know the possible reasons! the isp1362 driver did not suppot the isochronous ,I have modified the parameter of the isp1362 driver,Now, there wasn't the note:Isochronous transfer not supportec. Look forward to you reply! Thank you !
