20 years agoisp1362 usb hcd driver
this is the philips isp1362 usb hcd driver, ported from blackfin linux 2.6.16.1 . this is back ported patches for nios2 linux 2.6.11-uc0 . http://forum.niosforum.com/forum/index.php...ype=post&i...
20 years agoWhen clean all work before I do, I compile my kernel, I got so many errors, I using isp1362.diff to patch the usb driver.
<div class='quotetop'>QUOTE </div> --- Quote Start --- CC drivers/usb/host/isp1362-hcd.o drivers/usb/host/isp1362-hcd.c:1293: error: syntax error before "gfp_t" drivers/usb/host/isp1362-hcd.c:1294: warning: function declaration isn't a prototype drivers/usb/host/isp1362-hcd.c: In function `isp1362_urb_enqueue': drivers/usb/host/isp1362-hcd.c:1295: error: `hcd' undeclared (first use in this function) drivers/usb/host/isp1362-hcd.c:1295: error: (Each undeclared identifier is reported only once drivers/usb/host/isp1362-hcd.c:1295: error: for each function it appears in.) drivers/usb/host/isp1362-hcd.c:1296: error: `urb' undeclared (first use in this function) drivers/usb/host/isp1362-hcd.c:1333: error: `hep' undeclared (first use in this function) drivers/usb/host/isp1362-hcd.c:1334: error: `mem_flags' undeclared (first use in this function) drivers/usb/host/isp1362-hcd.c:1341: warning: implicit declaration of function `HC_IS_RUNNING' drivers/usb/host/isp1362-hcd.c: In function `isp1362_mem_config': drivers/usb/host/isp1362-hcd.c:2415: warning: int format, long unsigned int arg (arg 5) drivers/usb/host/isp1362-hcd.c:2418: warning: int format, long unsigned int arg (arg 5) drivers/usb/host/isp1362-hcd.c: In function `isp1362_hc_start': drivers/usb/host/isp1362-hcd.c:2776: error: `HC_STATE_RUNNING' undeclared (first use in this function) drivers/usb/host/isp1362-hcd.c: At top level: drivers/usb/host/isp1362-hcd.c:2818: error: unknown field `bus_suspend' specified in initializer drivers/usb/host/isp1362-hcd.c:2819: error: unknown field `bus_resume' specified in initializer drivers/usb/host/isp1362-hcd.c: In function `isp1362_remove': drivers/usb/host/isp1362-hcd.c:2828: warning: implicit declaration of function `platform_get_drvdata' drivers/usb/host/isp1362-hcd.c:2828: warning: initialization makes pointer from integer without a cast drivers/usb/host/isp1362-hcd.c:2834: warning: implicit declaration of function `usb_remove_hcd' drivers/usb/host/isp1362-hcd.c: In function `isp1362_probe': drivers/usb/host/isp1362-hcd.c:2927: error: too many arguments to function `usb_create_hcd' drivers/usb/host/isp1362-hcd.c:2932: error: structure has no member named `rsrc_start' drivers/usb/host/isp1362-hcd.c:2958: warning: implicit declaration of function `usb_add_hcd' drivers/usb/host/isp1362-hcd.c: At top level: drivers/usb/host/isp1362-hcd.c:3043: error: variable `isp1362_driver' has initializer but incomplete type drivers/usb/host/isp1362-hcd.c:3044: error: unknown field `probe' specified in initializer drivers/usb/host/isp1362-hcd.c:3044: warning: excess elements in struct initializer drivers/usb/host/isp1362-hcd.c:3044: warning: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c:3045: error: unknown field `remove' specified in initializer drivers/usb/host/isp1362-hcd.c:3045: warning: excess elements in struct initializer drivers/usb/host/isp1362-hcd.c:3045: warning: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c:3047: error: unknown field `suspend' specified in initializer drivers/usb/host/isp1362-hcd.c:3047: warning: excess elements in struct initializer drivers/usb/host/isp1362-hcd.c:3047: warning: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c:3048: error: unknown field `resume' specified in initializer drivers/usb/host/isp1362-hcd.c:3048: warning: excess elements in struct initializer drivers/usb/host/isp1362-hcd.c:3048: warning: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c:3049: error: unknown field `driver' specified in initializer drivers/usb/host/isp1362-hcd.c:3049: error: extra brace group at end of initializer drivers/usb/host/isp1362-hcd.c:3049: error: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c:3052: warning: excess elements in struct initializer drivers/usb/host/isp1362-hcd.c:3052: warning: (near initialization for `isp1362_driver') drivers/usb/host/isp1362-hcd.c: In function `isp1362_init': drivers/usb/host/isp1362-hcd.c:3063: warning: implicit declaration of function `platform_driver_register' drivers/usb/host/isp1362-hcd.c: In function `isp1362_cleanup': drivers/usb/host/isp1362-hcd.c:3070: warning: implicit declaration of function `platform_driver_unregister' drivers/usb/host/isp1362-hcd.c: At top level: drivers/usb/host/isp1362-hcd.c:3043: error: storage size of `isp1362_driver' isn't known drivers/usb/host/isp1362-hcd.c:1581: warning: 'isp1362_bus_suspend' declared `static' but never defined make[3]: *** [drivers/usb/host/isp1362-hcd.o] Error 1 make[2]: *** [drivers/usb/host] Error2 make[1]: *** [drivers/usb] Error 2 make: *** [drivers] Error 2[/b] --- Quote End --- I clean my work like as hippo mentioned in this topic: http://forum.niosforum.com/forum/index.php?showtopic=3706 (http://forum.niosforum.com/forum/index.php?showtopic=3706) <div class='quotetop'>QUOTE </div> --- Quote Start --- # remove old linux source rm -rf ~/linux-2.6.x ~/mysvn/2.6.11-uc0# kernel 2.6.11-uc0 source ported by microtronix cp -a ~/download/mx140/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~ cd ~/linux-2.6.x patch -p0 <~/download/kernel.diff cp ~/download/kernel.config ~/linux-2.6.x/.config patch -p0 <~/download/isp1362.diff[/b] --- Quote End --- Need I update my kernel or how to solve ?
