20 years agoisp1362 usb hcd driver
this is the philips isp1362 usb hcd driver, ported from blackfin linux 2.6.16.1 . this is back ported patches for nios2 linux 2.6.11-uc0 . http://forum.niosforum.com/forum/index.php...ype=post&i...
20 years agoHi,
I complie the isp1362 after I update my kernel 2.6.16.1, and there is no error now, and then I changed the usb Makefile ISP1362X to ISP1362, but I couldn't found the isp1362.o in host folder. When I boot uClinux on DE II board, I couldn't got any message about ISP1362. <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 008F0000 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6272k/8192k RAM, 0k/0k ROM (1332k kernel code, 471k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler deadline registered dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80900090, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 352k freed (0x15e000 - 0x1b5000) init started: BusyBox v1.1.1-pre0 (2006.04.18-08:58+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.04.18-08:58+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # [/b] --- Quote End --- I think ISP1362 wasn't work, how to solve it?
