20 years agoisp1362-hcd.c USB driver help
Hi everyone... I am trying to get the isp1362-hcd.c driver to work on a 2.6.11 kernel. the board is a ppc homebrew board... I think I have the driver basically working but I am new to the USB stuff...
20 years agoThanks Hippo...
yep, I am basically using the same source as nacide had in that message.. (yes, it is a ppc// motorola mpc8247 processor...) I don't there is anything wrong with the driver per say... since others have used it and seems to be working for them... it is probably something I did while getting it to work with my new board we built up.. (may even be a hardware problem.. not sure..) I am getting the interrupts ok.. (just not the ATL one I think.... which is what seems to unload incoming ptds... at least that is my guess).. I get the HUB timeouts... errors -110... so it is like nothing is coming back from the flash disk.. but the dmesg output seem s to indicate something did but just didn't get retrieved from the chip.. (via the ATL interrupt)... at least that is my guess.. not knowing usb that well yet, I am just guessing... thanks!! --- Quote Start --- originally posted by hippo@Jun 8 2006, 09:23 AM you may check the post from nacide, who backported the isp1362 hcd to 2.6.11,http://forum.niosforum.com/forum/index.php?showtopic=4069 (http://forum.niosforum.com/forum/index.php?showtopic=4069)
you should check if the platform device table is correct.
you should check if you can access ports on the usb chip, and interrupt is routed correctly.
but, are you working on ppc ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16036)
--- quote end ---
--- Quote End ---
