20 years agoIs using a single 25MHz oscillator feasible
We're starting to design a custom board using a Stratix II part and we'd like the board to be as small as possible. The board will have an ethernet device, SRAM, CFI flash, and the MAX progra...
20 years ago --- Quote Start --- originally posted by bkucera@Jul 3 2006, 04:05 PM we're starting to design a custom board using a stratix ii part and we'd like the board to be as small as possible. the board will have an ethernet device, sram, cfi flash, and the max programming cpld from the dev board.
assuming we go with the lan91c111 for the ethernet device, would it be feasible to use a single 25mhz oscillator for the entire board? the max's design only runs at 3.125mhz so that shouldn't be an issue, and a pll can be used to make a custom target design so the flash programmer can run at 50mhz.
anyone else tried this, or know of a potential issue with using a single oscillator for the entire board?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16635)
--- quote end ---
--- Quote End --- Ya. there won't be any problem in doing that. We have also tried the inverse: Using a 50MHz oscillator for NIOS and, using this 50MHz, deriving 25MHz LAN clock from PLL. Sincerely,
