17 years agois there any SOPC and NIOS2 design example of eeprom at93c46
in my design , i used one chip of eeprom: atmel 's at93c46, this memory 's interface looks like SPI interface. it has CS, CLK,DO and DI , but after reading it pdf document. i found it does accord wit...
16 years agoi tried and succeed.
i use 16 bits mode in the 9346's hardware pcb design(org pin tried high). in the sopc, i set the register length to 26, 26=16+6+3+1, 16: word length in the eeprom 6: 9346's address. in 16bit mode, it 's address scope is 0-63; 3: control code; 1: additional bit; set the clock phase to 0 and clock polarity to 0; i paste the file *.h and *.c , i hope it will helpful to someone.
