17 years agois there any SOPC and NIOS2 design example of eeprom at93c46
in my design , i used one chip of eeprom: atmel 's at93c46, this memory 's interface looks like SPI interface. it has CS, CLK,DO and DI , but after reading it pdf document. i found it does accord wit...
16 years agoi paste the read waveform of 9346 from datasheet. from the waveform, if i want to read 9346 a byte , i shoud write 1,1,0,a6-a0,9bit on the mosi, and read 8 bits from miso. if i set the the byte length to 8. the sequence is not compatible to the datasheet.
