17 years agois there any SOPC and NIOS2 design example of eeprom at93c46
in my design , i used one chip of eeprom: atmel 's at93c46, this memory 's interface looks like SPI interface. it has CS, CLK,DO and DI , but after reading it pdf document. i found it does accord wit...
17 years agowhy do you think that you can't use the spi interface sopc builder provides with this devices ? a quick look into the datasheet from atmel and this at93c46 has a spi interface.
or do you mean for AS (active serial) configuration of your fpga, for that you can't use it.
