20 years agoIs there a disassembler for Nios II ELF files?
I'd like to be able to examine the ELF file that the compiler generates so I can see exactly which instructions are being used. I have the Nios II Processor reference document which shows the opc...
20 years ago> Where is my linker command file,
Look in your system library path. E.g. for a debug build: xxx\Debug\system_description\generated.x > and how do I generate a map file? Pass the -Map option to the linker: $ nios2-elf-ld [OTHER OPTIONS] -Map app.map Use -Wl,-Map -Wl,app.map for gcc. Regards, --Scott
