Is it possible to run NIOSV through SDRAM ?
I have tried to make connection between "dbg_reset_out" to "ndm_reset_in" and also connected it to external sdram and jtag's reset.
With this configuration I again recompiled the design as well as build the software project. But still facing the same issue as I mentioned before. So this did not work out for me. I have attached the snap shot of QSYS system below for your reference.
Also I tried to download the ELF through "niosv-download command" but is doesn't make any differences as well. Lowering the JTAG Frequency to 6MHz also does not work out. So I am stuck at this point to debug further.
I tried to normally do write/read operations in the SDRAM. On-Chip-Ram was used as program memory for this. While doing so, it has been noted that I am able to do 16 bits of write/read transfers successfully. But not able to perform 32-bits of data transfers. May be this can be a issue while reading the ELF stored in the external SDRAM. I will look into this further from my end. But please share your suggestions as well.
Can you please share the PLL configurations for External SDRAM Part No : W9816G6IH ( WinBond ) which has been used on the Cyclone IV E FPGA. What is the minimum clock frequency that needs to be given to SDRAM and also at what phase shift ?
Besides that you can also suggest any fitter assignments which are required for external SDRAM in the QSF file.
Looking forward to hear from you !!!
Himanshu
Below is the snap shot of my SDRAM Controller IP configurations. Please have a look and verify if the configurations are correct for Cyclone IV E (EP4CE40F23C8).
Himanshu
- Vincent_F2 years ago
Hi Himanshu,
Like you, I've been looking for a way to use SDRAM together with the NIOS V. I came across your above post where you shared a Platform Designer screenshot of your system featuring a NIOS V and the SDRAM Controller Intel FPGA IP. I was wondering how you managed to have access to this controller, since it seems this IP is no longer supported on Quartus 23.1. Which version of Quartus do you use?
Thanks in advance for your help.
Best regards
Vincent
- himanshuvaria2 years ago
Hi Vincent,
I know that SDRAM Controller IP is no more supported in the latest Quartus Versions. But I would like to inform you that I have the .TCL file that will generate source of SDRAM Controller IP and it's path is added in the user_components.ipx file.(IP_IPX_PATH variable in System Environment) The .TCL will show the SDRAM Controller IP in the QSYS system. It is an older version of SDRAM Controller IP which I am using.
The SDRAM Controller IP, which I am using is from older Quartus 18.x version. To use in the latest Quartus Versions, we need to add the .TCL file in the IP_IPX_PATH variable which have file user_components.ipx.
You can ask INTEL to provide the TCL of the SDRAM Controller IP,
Himanshu
Hi Himanshu,
Thanks for your quick reply! I managed to import the .TCL from a previous version. Now I can find the SDRAM Controller IP in QSYS again, but unfortunately, it has no port interfaces. Did you face the same issue, and do you have any idea how I could fix it?
Best regards
Vincent
