13 years agoIs it possible to pass arguments to the main() function in NIOS II SBT
Hello, Just a generic question. I am using the NIOS II SBT eclipse for an application code and I would like to pass some values to the main() function. The syntax for a C program main() funct...
13 years agoHello,
Just a generic question about QSYS. I am a new bie to qsys (had used SOPC before) and I had been connecting the components together in the qsys builder. I clicked on each component in the Component Library and added to the system. One thing I have noticed is, unlike SOPC, the qsys do not automatically create the connections for the added components. I had to manually connect all the components as per my requirements in the 'Connections' tab under System Contents. So is this a feature in qsys or do I get to assign the qsys builder to make connections automatically (so that I may not have to manually connect every time) ? Thank You, Akhil
