meenalkb
5 years agoIs flash access Nios II/f only
I've been using the C10LP dev kit to test out the XIP option from EPCQ flash. This works fine with a Nios II/f core but not a Nios II/e - I assume this is because II/f provides an instruction c...
- 5 years ago
Nios II e/f can write and read data from flash.
For Nios II licensing, you can refer to below:
EricMunYew_C_Intel
5 years agoNios II e/f can write and read data from flash.
