20 years agoIs flash absolutely necessarily?
I'm now using the Microtronx nios2linux-1.4 to run linux on NIOS. When i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, t...
20 years ago --- Quote Start --- originally posted by bogwind@Sep 10 2006, 09:55 PM i'm now using the microtronx nios2linux-1.4 to run linux on nios.
when i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, the result is that i cann't go on with it.
is flash absolutely necessarily?if not, what should i do?
i'm a newer in nios,can anybody give me advice?thanks in advance!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18189)
--- quote end ---
--- Quote End --- The flash is needed for the root file system with romfs, if you use the Microtronix's kit. You must find other root file system, since you don't have flash. You may follow the nios wiki to use initramfs for root fs. It might save a lot of troubles.
