20 years agoIs flash absolutely necessarily?
I'm now using the Microtronx nios2linux-1.4 to run linux on NIOS. When i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, t...
20 years ago --- Quote Start --- originally posted by smalllight+sep 11 2006, 12:27 am--><div class='quotetop'>quote (smalllight @ sep 11 2006, 12:27 am)</div>
--- quote start ---
<!--quotebegin-bogwind@Sep 10 2006, 08:55 AM i'm now using the microtronx nios2linux-1.4 to run linux on nios.
when i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, the result is that i cann't go on with it.
is flash absolutely necessarily?if not, what should i do?
i'm a newer in nios,can anybody give me advice?thanks in advance!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18189)
--- quote end ---
--- Quote End --- you can download you system in your sdram indirectly.Then run it in sdram. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18205)</div> [/b] --- Quote End --- Thank u for your reply! When i build the project, it says that it needs a flash to upload the kernel to, if there isn't any flash, the NIOS II IDE wann't let you go on. So could you please tell me how could i download the system to sdram indirectily in detail?
