19 years agoIs anybody enable mtd and cfi flash successful?
Is anybody enable mtd and cfi flash successful use uClinux-dist-20060803 release , the kernel is linux-2.6.17-uc1??? If you successful please help
THX!!!!!6 Replies
--- Quote Start --- originally posted by andylei@Nov 27 2006, 05:26 AM is anybody enable mtd and cfi flash successful use uclinux-dist-20060803 release , the kernel is linux-2.6.17-uc1??? if you successful please helpthx!!!!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19635)
--- quote end ---
--- Quote End --- I just did it. It works fine. I've uClinux-dist-20060803 with patch V17. I just had a make error when "Detect non CFI / AMD / JEDEC compatible flash chips" was checked. LeFred.
Thank you very much LeFred!!
I use uClinux-dist-20060803 and patch all,is the reason here??? Will I try it only patch V17 ? Is it your meaning LeFred ? Thank you !! My "make" error is: drivers /mtd /chips /iedec_probe.c:196:error:'MTD_UADDR_0X1554_0X0AAA' undeclared here (not in function) drivers /mtd /chips /iedec_probe.c:196:error: is not constant drivers /mtd /chips /iedec_probe.c:196:error:(near initialization for 'jedec table[7],uaddr[0]) . . . - Altera_Forum
是中国朋友就帮顶一个 555!!!
I make is run Thanks all http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
congratulations!
--- Quote Start --- originally posted by smalllight@Dec 6 2006, 09:11 PM congratulations!<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19876)
--- quote end ---
--- Quote End --- Hi, I have the same problem. I am able to boot kernel but nor romfs from cfi. Could anybody help me? What I have to change in kernel configuration? Thx for reply
