20 years agoIRQ mapping in SOPC builder
I fixed up the device address (na_usb - to the address assigned to ISP1362 in SOPC builder) and irq (na_usb_irq - IRQ 4 when viewed in SOPC builder) and corrected the chip id so linux recognizes the ...
20 years agoWhy do you want bluetty?
If you want bluetooth support, maybe you should select from top level menuconfig, Networking --> [*] Bluetooth subsystem support ---> Bluetooth device drivers ---> [*] HCI USB driver The isp116x driver does not use DMA. It looks like the hcd driver crashed after detecting port <div class='quotetop'>QUOTE </div> --- Quote Start --- hub 1-0:1.0: 2 ports detected scheduling while atomic: swapper/0x00000002/1[/b] --- Quote End --- You should enable DEBUG in your driver, or add some printk() to find out. You should try out the 2.6.15.6 kernel in the update of the buildroot guide.
