21 years agoIRQ handler problem
Hi all, I have build an application on Stratix II, with three CPU's. I have ONE (!) pio line connected to the system of three CPU's. In the SOPC builder I connected the three CPU'...
21 years agoUsing 3 PIOs will enable you to turn off each signal in turn. However you need the logic to disable/clear the original interrupting hardware, plus once all 3 CPUs have handled the IRQ you need to re-enable all 3 of your PIOs. This could be done in software, but you'd be much better off desiging a bit of logic to solve the problem.
