15 years agoIRQ from PIO Not working.. Please help, very detailed
Hello i made a wrapper that does that:
always@(posedge rdclk)
begin
contador <= contador +1;
valid <= 0;
//rdreq <= 1;
wrreq <= 1;
wrclk <= 0;
if(contador == 50000000) //1segundo
begin
contador <= 0;
data_in <= data_in + 1;
wrclk <=1;
end
if (usedw_r==1)
valid <= 1;
end I am exporting this valid signal like that in my SOPC:
//fifo
.valid_from_the_fifowrapper_0 (valid),
.in_port_to_the_pio_0 (valid),
So my code generates the "1" and it goes inside the PIO. But it does not work, why? What configuration do i need to make this work?? This is my C code:
int main()
// Enable all 4 button interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(PIO_0_BASE, 0xf);
// Reset the edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(PIO_0_BASE, 0x0);
// Register the interrupt handler.
alt_irq_register( PIO_0_IRQ,&edge_capture, handle_button_interrupts );
alt_irq_enable_all;
printf("loop start");
while(1)
usleep(100000);
printf("---- %i ---\n",led);
return 0;
And this function..
static void handle_button_interrupts(void* context, alt_u32 id)
// Cast context to edge_capture's type. It is important that this be
// declared volatile to avoid unwanted compiler optimization.
volatile int* edge_capture_ptr = (volatile int*) context;
// Store the value in the Button's edge capture register in *context.
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(PIO_0_BASE);
// Reset the Button's edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(PIO_0_BASE, 0);
led=led+1;
//initdma();
// irq_count++;
1 Reply
It seems that this condition never happens
How can i get the half full signal from an assyncrhonos FIFO??? And am i writing right to the fifo with my code that i shown in the first post?if (usedw_r==1) valid <= 1;
