17 years agoiperf compile issues
Hi All, I am having difficulty compiling iperf application using C++ compiler. It is a network monitoring tool included in uClinux distribution. It seems there several problems with comp...
16 years agoHi,
I am facing issues with Iperf when I run the device under test as UDP streamer and iperf as the server I get the following error at the server end: [root@localhost src]# iperf -s -u -i 1 ------------------------------------------------------------ Server listening on UDP port 5001 Receiving 1470 byte datagrams UDP buffer size: 108 KByte (default) ------------------------------------------------------------ terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc Aborted Could you throw some light on what might be going wrong here. Thank you, Suneel.
