11 years agoIOWR_XXDIRECT latency
Hi all!
I'm experiencing some strange latency when using IOWR macros. I've added added custom 8-bit slave to QSYS and got huge number of cycles to read/write its registers. I thought that this issue related to some mistakes in my peripherial but then I've tried to read on-chip memory and got the same result! Here is the code, I'm using performance counter:int main() {
PERF_RESET(PERFORMANCE_COUNTER_0_BASE);
PERF_START_MEASURING(PERFORMANCE_COUNTER_0_BASE);
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE,1);
IORD_8DIRECT(ONCHIP_MEMORY2_0_BASE, PRER_LO);
PERF_END(PERFORMANCE_COUNTER_0_BASE,1);
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE,2);
IORD_16DIRECT(ONCHIP_MEMORY2_0_BASE, PRER_LO);
PERF_END(PERFORMANCE_COUNTER_0_BASE,2);
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE,3);
IORD_32DIRECT(ONCHIP_MEMORY2_0_BASE, PRER_LO);
PERF_END(PERFORMANCE_COUNTER_0_BASE,3);
perf_print_formatted_report(PERFORMANCE_COUNTER_0_BASE,50000000,3,"IORD_8","IORD_16","IORD32");
return 0;
} And what I get: http://www.alteraforum.com/forum/attachment.php?attachmentid=10849&stc=1 Ok, timer adds some time to this, as I measured, 30 clock cycles. So we have about 20 clock cycles per word, still bad. What could I do wrong? I'm using Quartus 15.0 Web Edition and Nios 2 Gen 2 /e.No RepliesBe the first to reply
