20 years agoIOWR and direct adress access
I can use IOWR,IORD and direct address access to operate SDRAM, But i can not use address to access Uart, for example: 1. use address alt_u8 * UartTxAdr; UartTxAdr = UART0_BASE+1; ...
20 years ago/* Here is my test code. To Test DMA from Memory -> UART
some of them cames from this forum. In The Terminal in My PC, I can see the followed data received ========================================= 0x68 0x65 0x6c 0x6c 0x6f 0x20 0x77 0x6f 0x72 0x6c 0x64 0x0a 0x30 0x31 0x32 0x33 ========================================= the first line is the "hello world" then i received 4 data send by IOWR macro after that, nothing received,even NULL. before DMA,i flush all cache,but nothing changed. the Timer is running,that means the dma transmit complete, but i do not know why nothing out from UART. */ # include "system.h"# include <stdio.h># include "altera_avalon_pio_regs.h"# include "altera_avalon_timer_regs.h"# include "sys/alt_dma.h"# include "altera_avalon_dma_regs.h"# include "alt_types.h" volatile alt_u8 count; static volatile int rx_done = 0; alt_u8 buffer[16] __attribute__((section(".onchip_ram"))); static void done (void* handle, void* data) { rx_done++; } void delay(void) { volatile int i; i=0; while (i<400000) i++; } static void handle_Timer0_interrupts(void* context, alt_u32 id) { alt_u8 a; volatile alt_u8 *countptr = (volatile alt_u8 *)context; IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_0_BASE, 0);//?TO?? a = *countptr; a=a<<1; if (a == 0x10) a=1; *countptr=a; IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, a); } void startTimer(void) { count=1; alt_irq_register(TIMER_0_IRQ, (void *)&count, handle_Timer0_interrupts); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0); IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, 7); } int main (void) { int rc; alt_dma_txchan txchan; FILE *uart; uart = fopen("/dev/uart0","w"); if(uart==NULL){ }else{ char *str="hello world\n"; fprintf(uart,str); } delay(); buffer[0]=0x30; //'0' buffer[1]=0x31; //'1' buffer[2]=0x32; //'2' buffer[3]=0x33; //'3' IOWR(UART0_BASE,1,buffer[0]); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 1); delay(); IOWR(UART0_BASE,1,buffer[1]); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 2); delay(); IOWR(UART0_BASE,1,buffer[2]); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 4); delay(); IOWR(UART0_BASE,1,buffer[3]); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 8); delay(); void* tx_data = (void*) &buffer[0]; /* pointer to data to send */ IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 1); if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 2); exit (1); } alt_dma_txchan_ioctl(txchan,ALT_DMA_SET_MODE_8,NULL); alt_dma_txchan_ioctl(txchan,ALT_DMA_RX_STREAM_ON,(void*)UART0_BASE+1); alt_dcache_flush_all(); alt_icache_flush_all(); if ((rc = alt_dma_txchan_send (txchan,tx_data,4,done,NULL)) < 0) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 4); exit (1); } while (!rx_done); alt_dma_txchan_close(txchan); IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 15); delay(); // end of DMA stream translate IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0); startTimer(); while (1) {;} if(uart) { fclose(uart); } return 0; }
