20 years agoIOWR and direct adress access
I can use IOWR,IORD and direct address access to operate SDRAM, But i can not use address to access Uart, for example: 1. use address alt_u8 * UartTxAdr; UartTxAdr = UART0_BASE+1; ...
20 years ago>When you use "direct access" you end up using stx/ldx instructions. When you use
the IOWR/IORD macros, you get the stxio/ldxio instructions. The "io" instructions bypass the data cache. thanks,Now i understand it , when a do the memory transfer, maybe it first move to data cache, not move to the address i what. >Do you mean you didn't see any data on your terminal? ... or nothing was transmitted at all? Your terminal software simply may not be displaying NULL Yes, nothing was transmitted, I made the terminal program in PC and it can display any data when received. I set the display mode in hex mode.
