20 years agoIOWR and direct adress access
I can use IOWR,IORD and direct address access to operate SDRAM, But i can not use address to access Uart, for example: 1. use address alt_u8 * UartTxAdr; UartTxAdr = UART0_BASE+1; ...
20 years agoHi hugeant,
> I do not know what different between these two way. When you use "direct access" you end up using stx/ldx instructions. When you use the IOWR/IORD macros, you get the stxio/ldxio instructions. The "io" instructions bypass the data cache. > but the data never send out from the uart Do you mean you didn't see any data on your terminal? ... or nothing was transmitted at all? Your terminal software simply may not be displaying NULL for example -- but the transmission may actually be occurring. If you're using a data cache, you should flush prior to calling alt_dma_txchan_send. The last time I looked at that code, it didn't flush the cache for you ... so it's your program's responsibility. You might be transmitting all NULL, since your buffer data is still in the cache (it was never written back). Regards, --Scott
