20 years agoIostream Problem
Hi all, I have recently posted a problem in the General Software Forum that I now know applies to more specifically when using the eCos library. Here are the posts: Hi, I have recently been using...
20 years agoi do not encounter this problem when i creat a .cpp project
"Unable to reach _impure_ptr (at 0x00000000) from the global pointer (at 0x04041e7c) because the offset (-67378812) is out of the allowed range, -32678 to 32767." about this problom ,you check size of your memory
