20 years agoIostream Problem
Hi, I have recently been using the Nios II v6.0 tools and downloaded and installed the eCos implementation for Neos. I went through the documentation for creating the eCos library and build...
20 years agoHi all,
More information... I was able to get this far (errors regarding "impure pointer" during link) only after changing a setting in my setup using the eCos Configuration Tool. The setting I changed was under "ISO C Library", "ISO C Library internationalization functions". I enabled "Newlib's ctype implementation". Prior to that I was using the defaults, which did not have this option selected. Instead, it had "Inline versions of <ctype.h> functions" selected. But using this default selection, I had a different set of errors, this time during compilation. They were: make INSTALL_DIR=/cygdrive/c/altera/ecos_library/eqam_install all nios2-elf-gcc -c -o hello.o -I/cygdrive/c/altera/ecos_library/eqam_install/include -g -O3 -ffunction-sections -fdata-sections -fno-rtti -fno-exceptions -fvtable-gc -DSYSTEM_BUS_WIDTH=32 -mhw-mul -mno-hw-mulx -mno-hw-div hello.cpp cc1plus: warning: switch "-fvtable-gc" is no longer supported In file included from /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/bits/locale_facets.h:132, from /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/bits/basic_ios.h:44, from /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/ios:51, from /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/ostream:45, from /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/iostream:45, from hello.cpp:2: /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:46: error: `_U' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:47: error: `_L' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:48: error: `_U' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:48: error: `_L' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:49: error: `_N' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:50: error: `_X' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:50: error: `_N' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:51: error: `_S' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:52: error: `_P' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:52: error: `_U' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:52: error: `_L' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:52: error: `_N' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:52: error: `_B' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:53: error: `_P' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:53: error: `_U' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:53: error: `_L' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:53: error: `_N' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:54: error: `_C' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:55: error: `_P' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:56: error: `_U' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:56: error: `_L' was not declared in this scope /cygdrive/c/altera/kits/nios2_60/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../../include/c++/3.4.1/nios2-elf/bits/ctype_base.h:56: error: `_N' was not declared in this scope make: *** [hello.o] Error 1 If anyone has a suggestion, I would really appreciate it. Thanks, Rennie
