21 years agoIORD_XDIRECT AND IOWR_XDIRECT?
Hello: Now I have some problems about the I/O Marco IORD_XDIRECT AND IOWR_XDIRECT.For example: I have a 16 bits slave periphery and the BEn0 ,BEn1 are both always low(means that th...
21 years agoHi mountain8848,
The stb and stbio are used to store a byte (from memory). The stbio instruction bypasses the data cache, the stb does not. The ldbu and ldbuio are used to load a byte (from memory). The lduio instruction bypassess the data cache, the ldbu does not. The "u" just means that the high-order bits in the target register are set to zero (unsigned) rather than being sign-extended. Regards, --Scott
