16 years agoIORD IOWR macros vs. memory access to peripherals
What is the point of the IORD and IOWR macros? I can access my custom Avalon peripherals using them, but it seems like I can't access them like the following: volatile alt_u32 *DEV_PTR = DEV_...
16 years agoYou just mentioned the difference. The macros avoid the cache - volatile does not - it only hints to the compiler that the value is volatile and not to optimize reads or writes to the variable.
It works if you do this:volatile alt_u32 *DEV_PTR = alt_remap_uncached( DEV_0_BASE, sizeof( alt_u32 *) );Bill A
