16 years ago"IORD_8DIRECT" reads 32 Bit ?
Hi, (I've tried to find something related to my problem, but without success. So I'm sorry if there is already a thread about this!) I've connected a parallel RAM over a tristate bridge to my...
16 years agoHere is what I would do to work around your problem:
Did you create a custom SoPC builder component or connect the component directly to an avalon tri-state bridge? Regardless, you need to configure your component as a 32-bit wide component. Let SoPC builder think that your external component is 32-bits wide. Then you can access it with any of the macros. You of course will only connect the lower 8-bits and disregard the upper 24. And of course you will do nothing with the upper 24-bits of data when you perform a read. This guarantees only one access to the peripheral each time the NIOS performs a read. Jake
