21 years agoIORD_16DIRECT causes 2 reads on a 16-bit data bus
A 16-bit write quite rightly performs a single write cycle. A 16-bit read performs two reads, with the next (word) address being read on the second cycle. Why? Simplification of the bus arbit...
21 years agoHi JasonDiplomat,
I hope you don't mind me tagging a question onto your post, but I also have this problem, but with 8-bit access and was about to start a post. Using Quartus/Nios V5.0, and a Nios II/e CPU, I have created a component as an 8-bit avalon_tristate_slave in Memory slave mode. When accessing this component, writes take a single bus cycle, but reads, take 4 consecuive cycles, reading from BASE to BASE + 3. Simple code example: volatile alt_u8 Test = 0; *(volatile alt_u8*)BPIO_BIDIR_BASE = Test; // Takes 1 bus cycle (as expected) Test = *(volatile alt_u8*)BPIO_BIDIR_BASE; // Takes 4 bus cycles (NOT as expected) This does not seem logical Can anyone explain what is going on here?
