16 years agoInvoke "Nios II Command Shell" in your development folder using a right-click
It can be tedious to invoke a "Nios II Command Shell" in a specific folder having a long path, because if you invoke it from the start menu "start->altera->nios ii eds->nios ii command shell", the cu...
15 years agoFor some reason the key and .reg script to invoking nios command shell no longer works on my Win7/64 machine. Chances are you would see the same problem so here is my fix:
to restore proper function remove the %1 parameter so the .reg script for creating now reads:Windows Registry Editor Version 5.00
@="NIOS II command shell here"
@="\"C:\\Altera\\10.1\\nios2eds\\Nios II Command Shell.bat\"" Assuming you use a default Nios2 path. If not just correct as needed. The remove script from above still works. All the \ and " are important! As before, it only works as expected in Win7 if invoked with right-click on a selected folder in the right pane of explorer. Enjoy.
