13 years agoInterval timer problem
Hello. I’ve got a problem with simple interrupt from interval timer in uC/OS-II System frequency is 75Mhz. There are PIO and timer. It makes strobe. Duration 10 ms. Here it is:
// glob...
13 years agoTo resume, you want to produce strobe with various durations.
This strobe signal is on an OUTPUT FPGA pin (destination : other device) right ? If you want hard real time (I mean that durations are strictly constrained and if one time is missed then fatal error), I don't recommand using software interrupts, because of what you have seen. --- Quote Start --- It’s hard to realize this staff on FPGA logic because it works closely to other subprograms. --- Quote End --- To produce strobe at various duration is not hard. You can load the value to a external (but inside FPGA) counter which produce strobe. To load the value, just employ a PIO ins Qsys. could you describe more of your project ? could you give a basic algorithm and structure of this part of your project (moslty relation between strobe and (sub)program)? Not enough info to help you and still confusing.
