13 years agoInterval timer problem
Hello. I’ve got a problem with simple interrupt from interval timer in uC/OS-II System frequency is 75Mhz. There are PIO and timer. It makes strobe. Duration 10 ms. Here it is:
// glob...
13 years agoHi, What do you want to see ?
Are timer interruptions happening at equal period : to verify the accuracy. If this is the answer, you go to the wrong way. or how many time does Nios take to initialize the timer ? Your program starts and stops at the first timer interrupt. Maybe I misunderstood something.
