20 years ago
interupt disabled in ISR
In the Nios II Software developer's handbook:
"the HAL system library disables interupts when it dispatches an ISR".
I've examine the file alt_irq_entry.S and alt_irq_handler.c but no presence of interupts disabling.
Could anybody tell me where are disabled interupts?
thank u in advance.
    When an exception is generated, the processor performs the following
    steps automatically:
    ■ Copies the contents of the status register (ctl0) to the estatus
    register (ctl1), saving the pre-exception status of the processor
    ■ Clears the PIE bit of the status register, disabling further hardware
    interrupts
    ■ Stores the address of the instruction after the exception to the ea
    register (r29), providing the return address for the exception
    handler to return to
    ■ Vectors to the exception address
    thank u for the answer David_Cai.
    This is the code of alt_irq_entry.S:
    * This is the interrupt exception entry point code, which saves all the
    * registers and calls the interrupt handler. It should be pulled in using
    * a .globl from alt_irq_register.c. This scheme is used so that if an
    * interrupt is never registered, then this code will not appear in the
    * generated executable, thereby improving code footprint.
    * Explicitly allow the use of r1 (the assembler temporary register)
    * within this code. This register is normally reserved for the use of
    * the compiler.
    .set noat
    * Pull in the exception handler register save code.
    .globl alt_exception
    .globl alt_irq_entry
    .section .exceptions.entry.label, "xa"
    alt_irq_entry:
    * Section .exceptions.entry is in alt_exception_entry.S
    * This saves all the caller saved registers and reads estatus into r5
    .section .exceptions.irqtest, "xa"
    # ifdef ALT_CI_EXCEPTION_VECTOR_N
    * Use the exception vector custom instruction if present to accelerate
    * this code.
    * If the exception vector custom instruction returns a negative
    * value, there are no interrupts active (estatus.pie is 0
    * or ipending is 0) so assume it is a software exception.
    custom ALT_CI_EXCEPTION_VECTOR_N, et, r0, r0
    blt et, r0, .Lnot_irq# else
    * Test to see if the exception was a software exception or caused
    * by an external interrupt, and vector accordingly.
    rdctl r4, ipending
    andi r2, r5, 1
    beq r2, zero, .Lnot_irq
    beq r4, zero, .Lnot_irq# endif /* ALT_CI_EXCEPTION_VECTOR_N */
    .section .exceptions.irqhandler, "xa"
    * Now that all necessary registers have been preserved, call
    * alt_irq_handler() to process the interrupts.
    call alt_irq_handler
    .section .exceptions.irqreturn, "xa"
    br .Lexception_exit
    .section .exceptions.notirq.label, "xa"
    .Lnot_irq:
    * Section .exceptions.exit is in alt_exception_entry.S
    * This restores all the caller saved registers
    .section .exceptions.exit.label
    .Lexception_exit:
    Which are the instruction that save registers and clears PIE bit?
    Probably I miss something.
    Thank u
    --- Quote Start ---
    originally posted by soin@Sep 13 2006, 02:21 AM
    which are the instruction that save registers and clears pie bit?
    probably i miss something.
    thank u
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18247)
    --- quote end ---
    --- Quote End ---
    As David Cai wrote this is automatically done by the processor, not the software. If you want nested interrupts you have to explicitly re-enable interrupts in your ISR.
    ok, perfect. I didn&#39;t understood clearly that.
    thank u all
    and just to be crystal clear, presumably all that needs to be done is something like the following:
    #include <io.h># include <system.h># include "sys/alt_irq.h"
    alt_irq_context IRQ_ALLOW_ESSENTIAL_START (alt_u32 id,  alt_u32* pActive)
      alt_irq_context Ctrl0;
      alt_u32 irq_mask;
    //mask out own IRQ and all others having lower priority level
        irq_mask = ~(0x0FFFFFFFF << id);
    // alternatively, mask out self and IRQs 32-29, 28-26
        irq_mask = (~(1 << id)) & 0x01FFFFFFF;
        *pActive = alt_irq_active;
        alt_irq_active &= irq_mask;
        NIOS2_WRITE_IENABLE (alt_irq_active);
    /*  alternatively......
      alt_irq_disable (id);                    //Prevent re-entry
      alt_irq_disable (<a lower priority interrupt that can wait>);
      alt_irq_disable (<another lower priority interrupt that can wait>);
      alt_irq_disable (<yet another lower priority interrupt that can wait>);
        NIOS2_READ_STATUS (Ctrl0);
        Ctrl0 |= NIOS2_STATUS_PIE_MSK;
        NIOS2_WRITE_STATUS (Ctrl0);
        return (Ctrl0);
    void IRQ_ALLOW_ESSENTIAL_FINISH (alt_irq_context Ctrl0,  alt_u32 id,  alt_u32 Active)
        Ctrl0 &= ~NIOS2_STATUS_PIE_MSK;
      alt_irq_enable (<yet another lower priority interrupt that can wait>);
      alt_irq_enable (<another lower priority interrupt that can wait>);
      alt_irq_enable (<a lower priority interrupt that can wait>);
      alt_irq_enable (id);
        alt_irq_active = Active;
        NIOS2_WRITE_IENABLE (Active);
    static void MyInterruptibleISR (void* context, alt_u32 id)
      alt_u32 Active;
    <time-critical section, e.g. reading registers>
      Ctrl0 = IRQ_ALLOW_ESSENTIAL_START (id, &Active);
    <non-time-critical section, e.g. stuffing in buffers>
      IRQ_ALLOW_ESSENTIAL_FINISH (Ctrl0, id, Active);
