21 years agoInterrupts in uClinux
Can someone please help me? I want to use the onboard buttons but I don't want to poll them continuously. With the altera_pio_button driver, 1, 2, 4 or 8 is written to /dev/buttons when a button ...
21 years agoHi Pierre,
Interrupts are not available for applications under Linux. My advice is, a. let your application block on reading the button device. It will return whenever the button is pressed. If your application needs to check more than one devices/files, use select/poll function. b. or, enhance the basic button driver in kernel to implement the asynchronous part --- sending SIGIO to the process that has openned the device. Your application needs to implement a signal handler for SIGIO. There might be a noticeable delay between the action and the response. Hope this helps, wentao
